03-07-2019 11:20 PM
Subject is clear.
My board is a 7020; and AES key is in eFuse registers. I've not programmed the R_EN_B_Key (Disables reading of AES key); so I assume I must be able to read it back. But how?
Dosto
03-10-2019 08:08 PM
Hi @f.m.dostoevsky-the-embedder ,
Xilinx doesn't recommend AES Key readback.
For security reasons, there is no Vivado Tcl command to read the 7 series AES key.
eFUSE registers can be read through JTAG ports. Table 5-18 lists eFUSE-related JTAG instructions. Refer page 104 of UG470 (v1.13.1).
Hope this helps.
Deepak D N
Please reply or give kudo or Mark it as an Accepted Solution.
03-10-2019 08:08 PM
Hope this helps.
Deepak D N
03-10-2019 09:36 PM - edited 03-11-2019 04:58 AM
Thank you @ddn!
Why it is not recommended?
I'm trying to get it through JTAG according to your reply. It looks like I have to deal with `jtag sequence`s which I couldn't make happen so far. This is the TCL I wrote using so few examples around the web; which prints 8 byte random data followed by ff's (like 1122334455667ffffffffffffffffffffffffffffffffffffffffffffffff) as the output eventhough I try it for different registers and bit sequences.
set seqname [jtag sequence]
$seqname state RESET
$seqname irshift -register fuse_cts_slr0
#$seqname irshift -bits 6 110001
$seqname drshift -capture 256
set result [$seqname run -hex]
puts $result
$seqname delete
Could you please guide me through reading it back? I cannot boot my module and have to check whether the key is properly written or not.
