How to select a flash for FPGA ?
Hi Expert,
     which aspect should be consider, if I want to select a compatible flash for FPGA?
     I have referenced the following reference,but the flash which I select is not in this list.(The flash I select is MT25Q,and FPGA is Spartan-6).
https://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/pim_r_supported_spi_bpi_proms.htm
What I want to know is that:
If I want to select a flash,what I know to consider is :
     1:Capacity:
                1)The bitstream size of the FPGA device can be load into the falsh
                2)If MultiBoot , need more larger
     2:Interface:
                1)If I use SPI X1, the flash need to support SPI X1 mode
                2)Flash CMD need compatible with FPGA configuration opcode(like 0x03 and 0xe8), as the attachment show.
     3:Impact need support this Device, or need to change the environment variable .
                   https://forums.xilinx.com/t5/Configuration/V6-LX240T-SPI-flash-N25Q256-Problem/td-p/646977
Are there other aspect need to consider?
you can use the MT25Q flash, check the following AR how to program this flash
https://www.xilinx.com/support/answers/68677.html
if you are going to use multiboot then try to use the flash part which can hold the number of bitstreams you will be programming
@kkn Thanks for solving my problem.
But if MT25Q is supported by iMpact, why not update the following information? This may convenience for us to reference.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/pim_c_introduction_indirect_programming.htm
Impact tool is matured tool and there are no change requests for this tool/doc. so this is the reason there is a solution record.
