Participant lanxiang.ben
How to set "NEXT_CONFIG_ADDR" for MultiBoot in Vivado2013.4
Hi All
     Reffer to 《Command Line Tools User Guide》(ug628)and ug470,,I want to use BitGen setting for next configuration address.Now,from《ug908-vivado-programming-debugging》,I know that via Tcl commend "set_property BITSTREAM.CONFIG.NEXT_CONFIG_ADDR 0x0 [current_design]"
,I can achieve it,But when I use it,There are some error as follow.
    Now,I want to know how to use the Tcl commend correctly?
Re: How to set "NEXT_CONFIG_ADDR" for MultiBoot in Vivado2013.4
You need to open the implemented design and then give this command to get it to work.
Anirudh
Anirudh
Hi athandr
As you say,I have already do it successful, Use this bit file as golden image and another bit file as multiboot image,generate a MCS file.But when I program it to flash by IMPACT,It is fail at the end.How can I handle?
what is the error message you get in impact? can you check the multiboot image location in the mcs file generation and the address in the bitgen of the golden image matches.
--Krishna
