mdshaheer05
How to use AXI-Stream?
I am working on a project where my fpga board has two camera connecters. The camera sensor board is been programmed in Altera. I have checked whether the camera is transmitting data by connecting the camera to the fpga board, used the SelectIO IP for the camera link receiver and confirmed the output with ILA. Till here, I have no issues.
Now the next part is that the data coming from the camera should be written to the DDR of the fpga board. I have tried to package my source code (i.e the code where I have checked the camera data using ILA.) into an AXI-Stream format. What should I do next?? I am still stuck at the packaging the source code into an IP part. Can someone help me with this??
Shaheer
