suicideengineer
How to use DNA Identifier with DNA_FUSE/DNA_PORTE2 in the PL-Based Design on the Xilinx UltraScale Device
I would like to ask a question this community.
I would like to create a PL design which has a PL-Based DNA Identifier ,so it works on the unique device only.
How can I do it? Are there any tutorials about it? Or, you can tell me how to do?
Best regards,
bruce_karaffa
UG 570, the Ultrascale Configuration User Guide discusses the DNA_PORTE2 which can be used to read the device DNA by the FPGA fabric.  I guess you would need toread the DNA over JTAG, then write your FPGA code to check for this DNA number before doing any processing.
suicideengineer
I would like to use UltraScale and UltraScale+ FPGAs' internal MASTER_JTAG port to program eFUSEs ,but I need some tutorials or reference design or someone's advice step by step about it.
wduffy
Hi @suicideengineer,
Have you reviewed XAPP1283?
https://www.xilinx.com/support/documentation/application_notes/xapp1283-internalprogramming-bbram-efuses.pdf
This uses the MASTER_JTAG primitive that allows internal programing of BBRAM and eFUSEs.
Wendy
Xilinx Technical Support
