IMPACT PROGRAM FAILED
Now I use a SPI FLASH(N25Q256) to configure the mcs file,but it can't program succeed,and the error is"ERROR:iMPACT:223 - '1': The calculated checksum (0x003a9035) differs from the expected checksum (0x019a82aa).
Failed at address, 0
'1': Verification Terminated
INFO:iMPACT - '1': Flash was not programmed successfully.
" But if I use N25Q128 to config,it's ok.I don't know why the N25Q128 can work ok,but the N25Q256 can't.
And please tell me what caused this  thank you !
In the supported SPI flash devices list, I didnt see the flash you are using as supported. See below snapshot:
What is the impact tool version being used?
And what is the device you are using?
THE version of impact i used  is 14.1 and the device is spartan 6
THE version of impact i used  is 14.1 and the device is spartan 6 .Can you know what causes this?please help me .Thanks
ok,I see .thank you very much
