INIT_B on Spartan 7- FPGA in reset?
    How do I put the FPGA in reset? Is it possible to put the FPGA in reset by holding down the INIT_B pin?
When INIT_B is low, does it mean that I can configure/program the external flash device and when I release INIT_B (high), the FPGA would read the flash and configure itself?
After programming the Flash then I should pulse PROGRAM_B?
Is this the right sequence:
1. Hold INIT_B low
2. Program flash
3. Release INIT_B
4. Pulse PROGRAM_B low
  Please confirm if my understanding is correct and I would appreciate input if I got it wrong.
Assumed you have seen this
https://www.xilinx.com/support/documentation/user_guides/ug470_7Series_Config.pdf?bcsi_scan_76a858e05751204b=NHbMUzrk0WkkKBynqh0T1IhpwpA8AAAAHZ9naw==&bcsi_scan_filename=ug470_7Series_Config.pdf
The FPGA does not as such have a reset.
   Once powered up , it is either configured or not configured ( though some app notes call this configuration reset !! )
INIT_B is a bi directional signal of the FPGA.
"INIT_B can externally be held Low during power-up to stall the power-on configuration sequence at the end of the initialization process."
During this time , the IO pins are either puled up or tri state , depending upon the PUDC_B pin.
Do you need the FPGA to be like this whilst you program the prom , or are you programing the prom throught the FPGA , in which case do not hold this pin low.
"Upon completing the FPGA initialization process, INIT_B is released to high-Z at which time an external resistor is expected to pull INIT_B High"
"When PROGRAM_B is pulsed Low, the FPGA configuration is cleared and a new configuration sequence is initiated"
Hi @drjohnsmith
  Thanks for your reply. I have read the config document.
   My current design programs the external flash through the FPGA and everything is working well.
   However, in my next revision of design, I wish to have an external processor (possibly a TI TM4Cxxx processor) to program the external flash. While the TM4C processor programs the external flash, I am hoping to put the FPGA in a "reset" state.
Yes, your above listed steps are correct for your next revision of design.
-Harshit
