ISE BitGen Command and Disable_JTAG
When BitGen is used in ISE and the Disable_Jtag option is used, what exactly does this do?
In the Xilinx Command Line Tools User Guide (UG629), it states " Disables communication to the Boundary Scan (BSCAN) block via JTAG after configuration."
- Is all JTAG usage disabled or just access to the BSCAN?
- Can JTAG still be used to view inside the FPGA device (i.e. read Control register, read eFUSE settings, etc.)?
- Does the FPGA behave normally other than the BSCAN access through JTAG is turned off, i.e. I/O's behave normally, internal functionality behaves normally, etc.?
Thank you Ivy!
-Mike
Disable JTAG will shut down JTAG ports. You cannot run any operations that require JTAG ports, including eFUSE, programming, etc.
Other function of FPGA won't be affected.
Ivy
Thank you Ivy!
-Mike
