Ibis model
Hello, I'm working with Virtex-6 FPGA and using PROM for the same, customized board.
I need ibis model of PROM for the signal integrity purpose.
Someone can suggest where I can find IBIS model file for PROM. I went throught plenty of links but not able to find.
PROM Part No.:
xcf128xftg64c
Thanks in advance.
回复: Ibis model
Hello @mtalati.18
Check this link : Platform Flash IBIS Models
You can get Xilinx Device IBIS model at this link https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/device-models/ibis-models/configuration.html
Bhushan
回复: Ibis model
Here it is:
https://xilinx-ax-dl.entitlenow.com/dl/2010/47/3/R11616/platformflash.zip/e6aee12c4d409d7a35238cedbb43398b/5D7604C3?akdm=0&filename=platformflash.zip
回复: Ibis model
This link is not reachable. It's showing file not found.
Can you check it once..
Thanks....
回复: Ibis model
Hello @mtalati.18
Bhushan
