Visitor huebnerie
Impact fails to program XC95144XL in chain
I have some boards with a chain of a XC95144XL and a XC2S200.
Impact in GUI mode shows them in exactly this order, but I don't get ANY operations in the left pane.
When I load a .jed file, I don't have any option to program the device.
In CLI mode, I can identify the chain (first is now the FPGA, followed by the CPLD?!), read back the XC95144s content, but when I try to program a file (assignfile -> program) I just get "Programming terminated due to errors."
The idcode test in the Impact GUI shows no errors, and the readback looks good.
Cable is digilent, I've used it on several Coolrunner II without issues.
regards!
>identify
Identifying chain contents...'0': : Manufacturer's ID = Xilinx xc2s200, Version : 8
INFO:iMPACT:1777 -
   Reading C:/Xilinx/14.2/ISE_DS/ISE/spartan2/data/xc2s200.bsd...
INFO:iMPACT:501 - '1': Added Device xc2s200 successfully.
'1': : Manufacturer's ID = Xilinx xc95144xl, Version : 4
INFO:iMPACT:1777 -
   Reading C:/Xilinx/14.2/ISE_DS/ISE/xc9500xl/data/xc95144xl.bsd...
INFO:iMPACT:501 - '1': Added Device xc95144xl successfully.
done.
Elapsed time =      0 sec.
>assignfile -p 1 -file "e:/cpld.jed"
'1': Loading file 'e:/cpld.jed' ...
done.
>program -p 1
Maximum TCK operating frequency for this device chain: 10000000.
Validating chain...
Boundary-scan chain validated successfully.
'1': Programming device...
'1': Programming terminated due to errors.
Elapsed time =      1 sec.
>program -p 1
Validating chain...
>bypass -p 2
Validating chain...
Scholar pratham
Re: Impact fails to program XC95144XL in chain
@huebnerie Can you please try using impact batch mode?
-Pratham
is the cpld purchased from the authorized distributor?
you can try with latest 14.7 impact tool for programming the cpld
https://secure.xilinx.com/webreg/register.do?group=dlc&htmlfile=&emailFile=&cancellink=&eFrom=&eSubject=&version=14.7&akdm=1&filename=Xilinx_LabTools_14.7_1015_1.tar
