Voyager
Voyager
Is JTAG the only one way to configure bitstream ?
HI Friends,
1)  Is JTAG the only one way to configure bitstream ?
2) Can we configure using Ethernet ?
3) please let me know all possible ways ?
NOTE: Any help or suggestions are highly appreciated.
Thank You
S Sampath
-Sampath
Hi @ssampath
There are following ways to configure for 7 series FPGA:
1. Master Serial
2. Master SPI
3. Master BPI
4. Master SelectMAP
5. JTAG
6. Slave SelectMAP
7. Slave Serial
For more details check UG470 (v1.13.1)
Similarly for Ultrascale and Ultrascale + FPGA supported config modes check UG570 (v1.9.1)
Master serial mode and Master SelectMAP mode are not recommended for UltraScale Architecture-based FPGAs
Bhushan
Bhushan
Hi @ssampath
1. Master Serial
2. Master SPI
3. Master BPI
4. Master SelectMAP
5. JTAG
6. Slave SelectMAP
7. Slave Serial
Bhushan
Bhushan
You can program the FPGA indirect via Ethernet.
Program the SPI boot flash memory and reboot the FPGA.
This is for instance done with FPGA-Cores.com remote programming tool.
See this Ethernet Cores
