wandol
Issue with BPI Flash programming of kintex ultrascale device
Vivado 16.2
KCU035 fbva-676 package
Flash Memory P/N is PC28F512P33BF(Micron) by BPI x 16 mode.
When I Programming configuration Flash memory at the below condition~
Mfg ID : 0   Memory Type : 0   Memory Capacity : 0   Device ID 1 : 0   Device ID 2 : 0
Performing Erase Operation...
Erase Operation failed.
ERROR: [Labtools 27-3161] Flash Programming Unsuccessful
ERROR: [Common 17-39] 'program_hw_cfgmem' failed due to earlier errors.
I confirmed the schematic for configuration and xilinx community Forums Q&A, I was read recommend doc. UG908,ug570,xapp1220 etc…
But still have problem.. like this..
vuppala
Hi @wandol
Share your configuration part of schematic?
Are you able to configure the device using JTAG?
Vinay
wandol
wandol
Q : Are you able to configure the device using JTAG?
A : It's working for configuration using JTAG.
wandol
