Issue with XC7A200T-2FBG676I (Artix 7) and VIVADO
Hi there, hope you can help me. Im thinking to use in new projects an Artix 7, the XC7A200T-2FBG676I, but i have a problem when i try to select it from Vivado
the XC7A200T-2FBG676I  means that has a speed grade of -2 and industrial temperature range of -40C to 100C
in Vivado when select Artix 7 Family, and range 'I', just i can select speed grade of -1
and if  select Artix 7 Family and speed grade -2 or -2L it doesnt appear the component with 'I' grade
this means that's not compatible Vivado with  the chip i wish to use?
or should i ignore that in Vivado doesnt appear the 'I' when i select speed grade of -2?
Im usign Vivado 2016.2
This PN i took it from DigiKey.
Thanks a lot!
Re: Issue with XC7A200T-2FBG676I (Artix 7) and VIVADO
Hello @pagustincorigliano,
This AR should be helpful
https://www.xilinx.com/support/answers/38221.html
Ashish
Ashish
thanks a lot @ashishd !!
Visitor blumeraluna
That AR is no longer available (404: Page Not Found), and I am facing the same issue for the industrial version of XC7A200T-2FBG484I. Is there a new version of this answer record available?
