crisilc
Kintex Ultrascale Config with MX25U51245G
I have a custom FPGA(Kintex Ultrascale) board with Macronix MX25U51245G as NOR for storing configuration bitstream. As per vivado, this device is a supporting part. I tried to erase config flash through vivado2018.2 and it fails. Vivado complains that it's unable to read the device id. From the log, MFG ID is received as 0.
Any clue about failure? Any suggestions for debugging?
Crisil
iguo
Have you tried with a new version of Tool? The support may be added later.
crisilc
Yes. I have tested with 2020.2
whxiao
Do you resolved this problem? I encountered the same question.
crisilc
Macronix has 2 devices starting with the part number "MX25U51245G".
Vivado works with only one of them which has the same part number as MX25U51245G
whxiao
My part number is MX25U51245GZ4I54 and vivado cannot detect this part
