08-29-2013 05:01 PM
I'm currently designing a system using an Artix XC7A200T-1156 and I'm forced to relocate DDR3 on banks 13,14 and 15. Because of this I have to drop the VCCO banks to 1.5V which are incompatible with the voltage levels described on XAPP586 (either 1.8V or 2.5/3.3V) for master SPI configuration.
Is it possible to use voltage translators to interface the SPI flash (as described in XAPP520) ? Would it cause problems if VCCO_14 is different from the voltage set by the CFGBVS pin?
There are already some posts on this issue but all are inconclusive. I would really appreciate if some insight is be given on this problem (or if someone already tried the voltage translator solution).
08-30-2013 04:36 PM
1) Banks 0 and 14 both at 1.5V will work just fine (CFGVBS = 0).
3) If you use only JTAG to configure the part (MCU or otherwise) then only bank0 is required for configuration. The Vcco bank voltage for 14+15 can be any.
08-30-2013 01:49 PM
Yes, this will be a problem. If you are using configuration pins in banks 14 & 15 they need to be using the same VCCO as bank 0.
08-30-2013 04:36 PM
09-01-2013 04:39 AM
Thanks for your prompt help :)
