Mini-USB(JTAG) to USB(PC) programming on Spartan-6 SP605
Hello.
Please understand I am new to FPGA and Xilinx.
I have a Spartan-6 FPGA SP605 and I have a trouble using the Mini-USB(JTAG) to USB(PC) connection through iMPACT.
I tried every sources I could find to program the board.
I did try to use install_drivers.exe in Xilinx\14.7\ISE_DS\ISE\bin\nt to get the "32-bit" driver to be installed but it doesn't work.
I also tried using command prompt(admin) to install the driver. And I am getting following messages below.
Please help me out. Thank you.
C:\Xilinx\14.7\ISE_DS\ISE\bin\nt>install_drivers.exe
Driver Installer - Version 1.21
Already in the installer executable location.
DriverInstaller->OS Version = Windows NT and later.
Major Version = 6, Minor Version = 2, SP = 0.
User is in the admin group.
WinDriver is not running.
Installing WinDriver6...
wdreg exepath=C:\Xilinx\14.7\ISE_DS\ISE\bin\nt\wdreg.exe.
install command=C:\Xilinx\14.7\ISE_DS\ISE\bin\nt\wdreg.exe -silent -inf C:\Xilinx\14.7\ISE_DS\ISE\bin\nt\windrvr6.inf install.
WDREG utility v10.21. Build Aug 31 2010 14:42:01
Installer exit code = 1.
DriverInstaller->ImagePath=\SystemRoot\System32\drivers\xpc4drvr.sys.
File version of C:\WINDOWS\system32\drivers\xpc4drvr.sys is 1040.
File version of C:\Xilinx\14.7\ISE_DS\ISE\bin\nt\xpc4drvr.sys is 1040.
Driver xpc4drvr.sys version = 1.0.4.0.
DriverInstaller->XilinxPC4Driver is running.
Error occurred during driver installation.
Tags (2)
Re: Mini-USB(JTAG) to USB(PC) programming on Spartan-6 SP605
Hi john.jlee007@gmail.com,
Please share the OS details.
Please go through this AR#18419 for ISE 14.7 supported OS.
Deepak D N
Please Reply or give kudos or Mark it as an Accepted Solution.
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
I am using Windows 10 with ISE 14.7.
I managed to work around applications to bypass to 32-bit mode, including opening iMPACT.
But I am having trouble programming the board like shown above.
Thank you.
Visitor semih96
hi
ı have the same issue.
ı am trying to program device
but it says" iMPACT:923 - Can not find cable, check cable setup ! "
can you help
my OS windows 8.1
ı  have ISE 14.7 for windows 10
Hi Guys,
To use ISE on Windows 10, you need the Virtual box as we don't support this on Win10:
https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/design-tools.html
Otherwise, make sure you are using a supported OS:
Windows XP Pro/Windows 7 Pro 32/64-bit/Windows Server 2008
