Ml605 Evaluation kit BIST problem
I tried to check ml605 BIST by using tera term as shown in pictures below ,
when I am pressing switch 3 and press any key from 1 to D to test the features I get error
but when i am pressing switch 4 and make the test again the test operates correctly and leds start to flash .
what is the problem then ?
should we  restore compact flash ?
should we  edit MHS and UCF files as shown in AR# 44814?
Should we replace our DDR 1 GB with another one 512 MB as shown in AR# 44814?
please check pictures below
test fail using sw3test fail using sw3test succeed using sw 4test succeed using sw 4sw 2 and sw 3sw 2 and sw 3
