Multiboot fails on KC705
I used the XAPP1247 to create a multiboot for my design on the KC705.
When I press the SW14 for PROG button, the fallback works fine.
But it doesn't work on board power up !
I corrupted the multiboot bitstream and I get the CRC_ERROR flag activated in the BOOT_STATUS register.
I guess I've missed something but I can't find what.
Any idea why the fallback process only executes on PROG_B button activation and not on power up ??
Thaks.
Stephane.
Re: Multiboot fails on KC705
Please make sure JTAG cable is disconneted when you are trying to boot from flash. Here is the AR https://www.xilinx.com/support/answers/66954.html
-Harshit
-Harshit
Hello harshit,
Thanks a lot it solved my problem !
Stephane.
