afantina
Multiboot fallback not occured
Hi all,
I have a problem with Fallback feature on Artix7 FPGA  connected to SPIx4 Flash device.
I generated Golden image with setup:
set_property CONFIG_MODE SPIx4 [current_design];
set_property BITSTREAM.CONFIG.SPI_BUSWIDTH 4 [current_design];
set_property CONFIG_VOLTAGE 2.5 [current_design];
set_property CFGBVS VCCO [current_design];
set_property BITSTREAM.CONFIG.SPI_FALL_EDGE YES [current_design];
set_property BITSTREAM.CONFIG.CONFIGFALLBACK ENABLE [current_design]
set_property BITSTREAM.CONFIG.NEXT_CONFIG_ADDR 0x0400000 [current_design]
Update image is on location 0x0400000:
Setup for generate .mcs file is like this:
When I was testing my fallback feature, I corrupted few bytes in my hex edditor to force CRC error (In the middle of the  Update.bit file). But when I program my flash device, here is what I see:
BIT5_0_CRC_ERROR is high, but fallback bit is zero... When I check WBSTAR value, it is correct - 0x00400000.
Can you help me with this issue? Why fallback not occured?
Br,
afantina
Tags (2)
