No boot from SPI memory when JTAG connected
Using XC7A200T-1FBG676C with SPI flash memory MT25QL256ABA8ESF-0SIT
Could programm the memory, but when JTAG is connected can't boot from SPI memory. With Jtag unconnected boot is OK.
M0 is 1, M2 is 0, M1 is 0.
Re: No boot from SPI memory when JTAG connected
Hi @markge,
This is an expected behavior. The JTAG port is considered the master communication method (also for recovery purpose), so if the board detects that a JTAG connection exists, it will interrupt any other configuration process and fall back to JTAG.
Please take a look at the following AR for instructions on how to overcome this issue:
https://www.xilinx.com/support/answers/66954.html
Andre Guerrero
Product Applications Engineer
Hi @markge,
Andre Guerrero
