Part Status Clarification Request
Hello Team,
Good day to you!
Could you please let us know the Current status (ACTIVE/DISCONTINUED/NRFND) of below listed parts.
Part Numbers:
  • XQ1701L-CC44B
  • 5962-9951401QYA      - Our end customer is claiming that part is Active
  • 5962-9951401QYB
Any help provided by you would be Greatly appreciated.
Thank you in advance for your time & support.
Stay Healthy & Stay Safe.
Sushil Kumar
I can see the first one in the Product discontinue Notice.
What are the part numbers of the next two? Are they XC95144 or some else? You can search in xilinx.com with the full part number and if they appear in PDN, then they are no longer available.
Hi Team,
Thank you so much for your kind response.
It would be a Great help if you please provide us the Current status (ACTIVE/DISCONTINUED/NRFND) of below listed parts.
Part Numbers:-
  • 5962-9951401QYB
Sushil Kumar
The remaining two part numbers are not Xilinx part numbers.  Those appear to be an internal part number.  Please find the full Xilinx part number associated with the internal part numbers and provide.
Hi Team,
Thanks for your kind response.
Please refer below given details for your reference & kindly do the needful.
Part Description:- Configuration Memory, 1MX1, Serial, CMOS, CQCC44
Have a Great Day ahead.
Sushil Kumar
I saw that XQ1701L-CC44B is suppose to be discontinued.
  1. Where can I find the PDN (Prod. Discontinue Notice)?
  2. What is the difference between XQ1701L-CC44B and XQ1701L-CCG44B?
  3. Is XQ1701L-CCG44B still an active part?
5962-9951401QYA appears to be the SMD (Standard Microcircuit Drawing) part # for XQ1701LCC44M
see this datasheet:
https://www.xilinx.com/support/documentation/data_sheets/ds062.pdf
And the PDN:
https://www.xilinx.com/support/documentation/customer_notices/xcn10019.pdf
Cheers,
bt
