Part Status Clarification Request
Hi Team,
Good Day to you!
Could you please suggest the correct parts status(Active/Discontinued/NRFND) for the below mentioned part. However, as per attached PDN-1 part- XCF04SVO20C will be supported till 2026 and replacement part is XCF04SVOG20C but now Xilinx has released a new PDN in which replacement part is EOL.
Sample Part Number:-
  • XCF04SVO20C
  • XCF04SVOG20CES
Thank you advance for your time & support.
Stay Healthy & Stay Safe.
Sushil Kumar
Hi @Sushilkumar2
I believe Key Dates and Ordering Information section provided in https://www.xilinx.com/support/documentation/customer_notices/XCN20013.pdf mightbe helpful for you.
Bhushan
