mmehrabi@asu.edu
Partial Reconfiguration on PYNQ
Hello all,
I want to implement a simple partial reconfiguration project on PYNQ. I designed a very simple project in Vivado and tried to download the partial part on PYNQ but when I want to download the partial part, the board halts and does not work. I attached a file that shows the details for this project and also the tutorial file by which the project is designed. I appreciate if one can help me to fix the problem.
kkn
can you try to add the failing partial part to be the initial design with full bitstream and see if this works fine, this is to see if the issue is in design files or in the partial design flow
mmehrabi@asu.edu
I did that. It is working. It is a very simple functionality. Do I need partial reconfiguration decoupler for each port connected to the static part?
davidd
mmehrabi@asu.edu,
Adding decouplers would be a wise next step.  The question to answer is why the board stops working?  If the act of reconfiguration is the trigger, there could be some unexpected event from the reconfiguring region that is not handled well by the static design.  Adding decouplers freezes activity on the outputs to prevent unpredictable behavior.  You could also add debug logic (ILA cores) to monitor internal activity before, during and after partial reconfiguration to find the source of the issue.  But overall, you know your design best.  Would unpredictable transitions on the RP interface cause the behavior you are seeing?
thanks,
david.
