saeedgh96
Problem with Install the usb driver and Assigning a Static IP Address for smartlynq
Note: I use vivado 2017.4 in windows 7 and  according to the description of (AR# 69951) I upgraded the firmware of smartlynq  to 2017.4.
Problem 1:
 When I connect with usb in first time, Windows automatically installs the device driver. When complete, a message appears: Smart JTAG Cable installed. Then an IP address appears on the display(10.0.0.2). according to the description of  UG1258 page 10  when I Open the Hardware Manager ,and  I choose the Remote server and specify the IP address shown on the SmartLynq Data Cable display. but  I could not connect  to the target board.( A message appears that the usb cable is not connected)
Problem 2:
I'm giving the smartlynq  a dynamic ip using a server computer(Connect through Ethernet). Then connect the smartlynq to a computer with Windows 7 and use the vivado 2017.4 to connect to the target board according to the description of  UG1258 page 7(There is no problem so far).
When I work to change the ip according to the description of  UG1258 page 19 , I encounter the following message:
[labtoolstcl 44-629] could not update smart cable. Unable to open  source file config.ini
I find the location of the project file using the tcl (set_property directory [current_project])  command and  my config.ini file is placed on the track found.
Please check my configuration file. If there is a problem guide me.
kvasantr
Hello @saeedgh96,
Once device driver has been installed please unplug the cable and plug it again in the same port.
Please try with a different evaluation board as well.
Make sure that ribbon cable is connected correctly on board.
I tried with 2017.2, 20217.3 as well as 2017.4 version of VIVADO tool.
It works well.
Are you seeing this behavior since initial or it worked for some time ?
Which OS are you working on ?
Please try with a different machine.
Thank you.
