sraza
Problems in Condiguration using BPI flash in Virtex 6 ML605
Dear all,
I am trying to configure ML605 using BPI memory, but whatever I do it does not get succeded.
I have selected the Mode pins 010 , with S2 pin 2 high as well... and all other requiremnts.
I have seen the process properties of the 'generate programming file' option in project navigator. I also made done pin high from there. It is then showing programming successful, but when I restart my FPGA...All Blank ...
Can any one suggest detailed tutorail (other than xapp for programming V5, I have tried that as well)...
Also can anyone suggest any detailed help where I can learn more about process properties of 'generate programming file', since I guess I can achieve things by pulling up or down resistors from there... Well I am gonna try this any way.
Please help.
Really messed up,
Shan
Anonymous
Not applicable
Hi Shan,
   You can use the ML605 Reference designs.  Located at http://www.xilinx.com/products/boards/ml605/reference_designs.htm each one of these reference designs has a Tutorial that goes along with it.
Kyle
Anonymous
Not applicable
Hi Shan,
Kyle
san_2190
hi shan,
is your bpi flash programmed and working correctly ?? i need some help ..... im getting 'program failed' when i program my flash using impact .... help on this
-San
