Programming ML507 Platform Flash using iMPACT
I have a xc3s1500 FPGA and a xcf32p platform flash. I want to program the FPGA and then I want to write to the Flash. So I have:
1)
setMode -bs
setCable -port usb21 -esn 0000171741D601 -baud 6000000
Identify
identifyMPM
assignFile -p 2 -file "download_sdk.bit"
program -p 2
cleancablelock
exit
and
2)
setMode -bs
Identify
identifyMPM
assignFile -p 1 -file "flash.mcs"
Program -p 1 -e -defaultVersion 0
cleancablelock
exit
FPGA programming works and I see the outputs on the console.
For Flash programming, I also see in impact log "Programming completed successfully." However nothing comes to the console when I power-cycle my board.
If I execute the second script alone, everything is fine.
My question is: Could it cause a disturbance during the Flash programming, if the FPGA is not empty?
Berk
Re: Programming ML507 Platform Flash using iMPACT
Sorry for the topic. I made a typo. Please ignore the "ML507".
could you share the status registers of the fpga when it fails to configure from flash after power cylcing of the board.
--Krishna
