Programming Platform Flash from Vivado Device Manager- Parallel Load Option Setting Missin
Hi Everyone,
We're using Vivado 2019 Lab Tools Device Manager to load a bit file into an XCF16P Platform Flash part. These parts have an option for either serial or parallel FPGA configuration load and we need parallel load to get a fast startup. In ISE/iMPACT there was a menu option to select this. However Vivado Device Manager does not seem to have this option.
Can anyone suggest how to deal with this?
phillipsrb
Re: Programming Platform Flash from Vivado Device Manager- Parallel Load Option Setting Missin
May be you can share some snapshot from ISE/Impact then I can look into this. Which FPGA device you are using?
-Harshit
