Programming Xilinx CPLD's using impact in Win 10
Hi - I have recently upgraded to Win 10 and can no longer use Impact to programme CPLD's (Impact not supported > win 7 as far as I know). Is there any alternative software we can use in Win 10 and a USB Xilinix programmer?
Myself and the team work in CARE and we are very light users programming "older" families of CPLD's only.
Re: Programming Xilinx CPLD's using impact in Win 10
Hello @ritchiemidas,
Yes, we have not officially tested programming CPLD devices using iMPACT on windows-10.
while we will recommend you to stick to windows-7 for using iMPACT.
while you can try re-installing the cable drivers.
https://www.xilinx.com/support/answers/54381.html
Also refer other forum posts more help on this.
Thank you
Thanks @kvasantr for the quick reply, I have already tried this to no avail.
Is there any other Xilinx software packages that you can use as an alternative that are win 10 compatible?
Unfortunately answer is no.
Both iMPACT and CPLD are legacy products of Xilinx. Because of that we have no solution for them to work on windows-10.
Meanwhile we have workaround mentioned in following answer record to properly install the tool.
Thank you
Scholar u4223374
@ritchiemidas
For what it's worth, we use Xilinx Lab Tools 14.7 (basically just iMPACT, no capability to write/build code) on Windows 10 x64 and, after a little bit of messing around (disable SmartHeap) it works fine.
