Programming of ZC706 via JTAG USB
Hi Everyone,
I am using the ZC706 Eval board and trying to program the FPGA device. However I came across 2 issues while programming via Hardware Manager. Here are some snapshots regarding this issue.
It says programmed on the top, instead of Device xc7045 (JTAG device index = 1) is programmed. (DONE status = 1).
Any help is highly appreciated. Thank you.
Suraj Kothari
Scholar hbucher
Re: Programming of ZC706 via JTAG USB
@suraj.kothari Last time I got this was a glitch with another board.
Disconnect any other boards you have, even if they are powered down.
Kill the hardware server (hw_server.exe in Windows Task Manager) and restart Vivado.
Scholar hbucher
Hi @hbucher:
Thank you.
I haven't connected any other boards except this one.
I tried your method and ended all the processes related to Xilinx such as cmd.exe, conhost.exe, vivado.exe and hw_server.exe.
This helped me detect and successfully program the FPGA.
I still have to connect other boards to this board and program each one sequentially.
Thanks once again. Your solution helped.
Suraj
