Programming terminated. DONE did not go high....
Hi All,
I have one spartan 6 board from ex-colleague, and I also meet the same problem.(I attach the log in the last paragraph)
I check the previous solution but not help at all.
I tried:
1.change the "Unused IOB Pins" property to "FLOAT"
2.selecting "Use HighZ intstead of Bypass"
3. slow down the cable speed
Can someone give me any guidance?
PS:ISE14.7   win7  64bits
Validating chain...
Boundary-scan chain validated successfully.
'2': Programming device...
LCK_cycle = NoWait.
LCK cycle: NoWait
done.
'2': Reading status register contents...
[0] CRC ERROR : 0
[1] IDCODE ERROR : 0
[2] DCM LOCK STATUS : 1
[3] GTS_CFG_B STATUS : 0
[4] GWE STATUS : 0
[5] GHIGH STATUS : 0
[6] DECRYPTION ERROR : 0
[7] DECRYPTOR ENABLE : 0
[8] HSWAPEN PIN : 1
[9] MODE PIN M[0] : 1
[10] MODE PIN M[1] : 0
[11] RESERVED : 0
[12] INIT_B PIN : 1
[13] DONE PIN : 0
[14] SUSPEND STATUS : 0
[15] FALLBACK STATUS : 0
INFO:iMPACT:2219 - Status register values:
INFO:iMPACT - 0010 0000 1100 1000
INFO:iMPACT:579 - '2': Completed downloading bit file to device.
INFO:iMPACT:188 - '2': Programming completed successfully.
LCK_cycle = NoWait.
LCK cycle: NoWait
INFO:iMPACT - '2': Checking done pin....done.
'2': Programming terminated. DONE did not go high.
PROGRESS_END - End Operation.
Elapsed time = 3 sec.
looks like it all worked, then did not go "don".
Thats great as it menas most of the problems are solved,
do you have a pull up resistor on the done pin ?
out with scope, see what voltages and wave forms your getting.
I dont think it is, , but also double check the obvious that your trying to program the right device with the right file
The data did not shift into Spartan-6 completely. Are you sure you are using a correct bit file? Change the Mode pins to 1 1 and try again please.
Hi drjohnsmith,
1. I attach the circuit about the DONE pin. I also measure the waveform about DONE pin, and yes, there is pull-up resistor(R73:330ohm, series with LED) in DONE pin.
2. I check the "DONE pin" waveform when programming. DONE pin go down to 0V for 2s and go up to 3.3V, then show "Program Failed".
Hi iguo,
I attach the MODE circuit, and there are pull-up/down resistor on it.
Current configuration is showed as the figure, MODE0=1, MODE1=0.
Do you mean I need to pull MODE1 to high?
