Observer ppouyan
Programming the NAND
Is there an approach to program the NAND Flash on a custom ZYNQ board without using the JTAG and SDK?
For example is it possible to program the NAND from SD-Card or by using UBoot?
Scholar drjohnsmith
Re: Programming the NAND
you have a processor,
once it has booted, you cna read and write the nand ,
for instance, boot off JTAG, and then copy SD card to NAND is quiet possible,
Its just code, you write,
https://www.xilinx.com/support/answers/56030.html
https://www.xilinx.com/support/answers/59311.html
https://forums.xilinx.com/t5/ACAP-and-SoC-Boot-and/Failed-to-program-boot-image-into-NAND-Flash/td-p/867751
Observer ppouyan
Thanks @drjohnsmith
So I boot from SD-Card (running UBoot), then can I copy the SD-Card boot.bin file into the NAND flash?
Scholar drjohnsmith
that would work, just code you have to write.. can you read / write the parts from uBoot, I'd have thought you would have to booted to Linux / your code, but that's up to you
Observer ppouyan
Thanks @drjohnsmith
Can you please expalin what do mean by writing code? What kind of code? Code for FSBL or Uboot or etc?
Scholar drjohnsmith
yes to both,
