Programming the XQ7Z100-2RF1156I through the JTAG port.
Ok. Hopefully I can get the answer to this in a timely manner.
I am trying to program the XQ7Z100-2RF1156I through the JTAG pins (using a 93K tester). Took the .svf file from the design tools. Passed it through the svf2vcl236.exe conversion tool. Using our in house software, turned the .vcl files into a .avc file for the 93K tester.
(If anyone is interested, this software will produce Nextest and J750 tester patterns as well).
Ok, here's my problem, I can't get the part to program, and am not seeing a DONE pin output transition.
I do not see any mode pins clearly defined for this component. I did not find any clear and concise instructions on how to program this part in any documentation using JTAG alone although it says it can be done. Need help from technical support in getting this done.
Thank you,
Thorne Kontos
Integra Technologies LLC
I'd also settle for reading the JTAG device ID or invoking BYPASS at this time. (Same problem, how do I properly set up the JTAG port for proper operation on this component?)
