Programming xc6slx16 with ISE Command Prompt
Hey, so I'm an intern at this company and I'm new to using Xilinx tools and programming FPGAs. For my specific task, I'm supposed to program these boards using iMPACT. I was given an image (.msc) file to use and I'm able to program these boards using iMPACT, but I wanted to speed up the process so I tried doing the programming through the ISE Command Prompt.
Here are the commands I used.
impact -batch
setMode -bscan
setCable -p auto
addDevice –p 1 –spi xc6slx16 -file "C:\Users\XXXXXXXXX\Desktop\RF Board/rf_fpga_golden_and_latest_multiboot.mcs"
program -p 1 -dataWidth 1
After running the program command, I run into an error where the command prompt displays "address is not continguous".
回复: Programming xc6slx16 with ISE Command Prompt
-spi should be followed by the spi part name. FPGA name should be removed. This command was to assign mcs to a FPGA.
Hi, so I went ahead and tried that and I ran into another error now.
>addDevice -p 1 -spi N25Q128 -file "C:\Users\XXXXX\Desktop\RF Board/rf_fpga_golden_and_latest_multiboot.mcs"
INFO:iMPACT:1111 - Can't locate bsdl file n25q128.bsd.
INFO:iMPACT:131 - N25Q128 is not supported in Boundary Scan mode
INFO:iMPACT:882 - Part 'N25Q128' could not be added because it is not supported
in this mode.
ERROR:iMPACT:894 - Failed to add PROM device N25Q128 at position 0.
Same issue when I had qoutation marks around the spi part name.
So I was able to fix my errors by running these commands instead,
CD /D C:\Xilinx\14.7\LabTools %root%
call settings32.bat
impact -batch
setMode -bscan
setCable -p auto
Identify -inferir
identifyMPM
ReadIdcode -p 1
attachflash -position 1 -spi "N25Q128"
assignfiletoattachedflash -position 1 -file "C:\Users\Mastodon Factory 03\Desktop\RF Board/rf_fpga_golden_and_latest_multiboot.mcs"
Program -p 1 -dataWidth 1 -spionly -e -v -loadfpga
I wanted to create a batch file that would run these commands automatically but whenever the batch file does the impact -batch command, it doesn't continue. If I was to enter the commands manually in a CMD then it works though. Any advice?
Hello @yuvrajsingh
Create batch mode command file from the impact log which includes all the commands you have executed.
Bhushan
