_elham
ReadEfuse failure
Hi all,
I'm programming spartan6 device's efuse register. when I give efuse "ReadEfuse -aeskey -p 1" command to read back efuse, I get all-zero for AES key register. I got this all-zero in both programmed and non-programmed efuses in different devices.
I cannot write efuse with a non all-zero key!
I appreciate any help,
Elham
iguo
https://www.xilinx.com/support/answers/47802.html
Try readdna, do you get correct dna values?
How did you program efuse? Did you program the Key security bit?
