Reading SPI Flash Device contents I get failure at address 65536 ??
Here is SPI flash programmed failed log:
PROGRESS_START - Starting Operation.
'1': ID Check passed.
'1': Erasing Device.
'1': Using Sector Erase.
'1': Erasing non-volatile quad-enable bit...
'1': Programming Flash.
'1': Reading device contents...
Failed at address, 65536
'1': Verification Terminated
PROGRESS_END - End Operation.
Elapsed time =    182 sec.
Re: Reading SPI Flash Device contents I get failure at address 65536 ??
Which version of impact you are using? Do have any other version installed to try flash programming again! If you can try with 14.1 or older.
Also what happens if you disable the verify options? Does it passes the programming?
Harshit
