Recommended BPI flash for Xilinx Ultrascale and UltraScale+ devices
We plan to use a BPI flash with Xilinx UltraScale and UltraScale+ devices to meet the 100ms boot requirement for PCIe.
Is there any particular family of flash recommended by Xilinx which will meet our requirements.
Ayusman
Re: Recommended BPI flash for Xilinx Ultrascale and UltraScale+ devices
@ayusman100488 Check Appendix C of UG908 https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug908-vivado-programming-debugging.pdf
- Giri
@ayusman100488 As mentioned, You have to refer UG908 for the supported flashes and choose the one that meets your requirement. You may also check VCU108 tandem example and flash used (MT28GU01GAAA1EGC-0SIT) for the reference.
#86
http://www.xilinx.com/support/documentation/ip_documentation/pcie3_ultrascale/v4_2/pg156-ultrascale-pcie-gen3.pdf
-Pratham
@pratham@gnarahar
I saw the recommended BPI flash parts mentioned in the UG908. The micron parts are available in 2 options.
- Supports Synchronous read
- Supports Asynchronous read
The part used in VCU108 EVM supports synchronous read but is currently EOL pending. Actually all the synchronous read parts from Micron are EOL pending. Only the asynchronous read parts are available in production.
My question is that with asynchronous read parts, the effective clock rate for read reduces by almost half and for some FPGAs this may lead to more bitstream loading time. This will in turn make it difficult to meet the 100ms boot requirement for PCIe.
Ayusman
@ayusman100488 Did you check with the Micron for the replacement of MT28? also for other NOR synchronous parts?
-Pratham
@pratham
I checked with them. The alternates they have suggested are all asynchronous read parts. I was wondering this issue would be faced by other customers also and Xilinx would be aware and help us out in this.
Ayusman
Let me take a look into this. I will get back to you.
-Pratham
Is there a solution for this issue.  We have the same problem.  Looking for a BPI flash recommendation to replace the Micron parts that will be obsolete.
How did you solve this issue?
@vidriodevelops, I'll contact you offline regarding this issue.
Hi ,
  would you please share on the forum your findings on this flash issue?
We have a xcku15p ES2 (Engineering Sample) and Vivado doesn't support neither Tandem PCIe nor Tandem Flash, so we need to select Synchronous flash (faster than Asynchronous) in order to fit the PCIe "100 ms boot time requirement".
Hi All,
I'm facing the same problem of Micron Synchronous BPI going to be EOL. May I know what are the recommended BPI options?
@fscandro_pri, @sngyeongkain, if this is still an issue for you, please contact your local Xilinx FAE.
Hello @vidriodevelops @sngyeongkain @fscandro_pri,
Yes, its true that synchronous BPI flashes of Micron are going end of life and there is no plan as well to update this list in future as well.
To meet this timing constraints one should opt for Tandem PCIe mode of configuration.
In this method one can attain all the fast configuration requirements by implementing the Bitstream compression.
Please refer configuration user guide and AR#64761 for more help.
Hope this helps.
Thank you.
