07-29-2014 11:48 PM
I would like to know how the IPROG command and WBSTAR address value is included in BitGen. I understand that IPROG command and WBSTAR can be issued either in BitGen or using ICAPE2. How do I set these values in the bitsream in BitGen? Thanks.
Surya
07-30-2014 12:05 AM
Hi Surya,
You need to use the switches shown in the attached snippets to embed IPROG and warmboot address in bitgen settings.
Krishna
07-30-2014 12:05 AM
Hi Surya,
Krishna
07-31-2014 02:48 AM
Thanks Krishna. I am able to change the WBSTAR and IPROG like you have mentioned in BitGen. Now, I have the golden image from 0x00000000 and update image from 0x00400000 in Flash. To follow Multiboot and fallback method, can you pls tell me the required settings to be given in the BitGen. I have given the appropriate addresses. For a succesful update image, FPGA is getting configured from the update image on power on. But for an unsuccessful update image,the fallback isn't working. I'm wondering if I have given the setting properly in BitGen. Thanks.
Surya
07-31-2014 06:14 AM
08-01-2014 05:39 AM
Hi Krishna,
I have enabled -g Config:Fallback in multiboot image settings. And yes, starting address for fallback configuration is 0x00000000. It works this way, but the fallback takes a bit of time, about 40-60 seconds, for configuration of golden image.Thanks.
Surya
08-03-2014 11:44 PM
08-03-2014 11:51 PM
Hi Krishna,
On unsuccessful programming of update image, on power off and power on, configuration of golden image takes time, i.e., it is not configured immediately. It takes about a minute(maximum) or so.
Surya
08-04-2014 11:41 PM
Hi Krishna,
On power off, flash tries to configure the FPGA with update image, and if this fails, it tries to reconfigure from the golden image. But say, I'm dynamically programming the flash with an update image, and after the flash programming is done in the update region, it should immediately configure from the update image right? So, in such a case, should IPROG be issued from the user application? IPROG embedded in BitGen will not take care of this case right? Thanks.
Surya
08-05-2014 02:22 AM
08-05-2014 02:52 AM
Hi Krishna,
Thanks. So, in such a case, after we reprogram the flash with an update image, we need to trigger the multiboot configuration from user application. Okay. Say, that update image is a corrupted one, then it will configure the golden image, on realising that the update image is a failure, right? And what is the procedure to trigger from user application? Thanks.
Surya
08-05-2014 04:35 AM
08-05-2014 09:09 PM
Thanks Krishna. I will look into the configuration user guide, and reference designs,like you have suggested. Thanks.
Surya
08-26-2014 02:34 AM
In multiboot case, we have two images, one golden at 0x00000000, and update image at 0x00400000, the settings we have given for the images are-
Golden Image-
Multiboot Image-
Now, when we program the Flash at 0x00400000, with a successful update image, it is configured immediately, and succesfully , on power on too. And when we program it with a corrupted update image at 0x00400000, then it falls back to the intial image, also successfully.
But say, while programming the Flash with an update image, if it is interrupted by a power cycle, then it should fallback to the initial image, right? But this doesn't happen. Pl. guide us, where we could be going wrong. Thanks.
Surya
