SDK 14.4 debug issue
Tool : Vivado 14.4,
Board : FPGA custom,
Device : XC7Z020CLG400-2,
issue: I  am working on zynq device ,using xilinix jtag,through SDK Programming is Done i.e..BIT file is downloaded to FPGA ,But application is not debugging one errror is occured,i.e. Error while launching program:error while running ps7_init method.
How to solve this error.
Re: SDK 14.4 debug issue
hi,
can you check if this works in XMD console?
fpga -f bitstream
connect arm hw
source ps7_init.tcl
ps7_init
ps7_post_config
dow application.elf
run
--hs
hi,
fpga -f bitstream
connect arm hw
source ps7_init.tcl
ps7_init
ps7_post_config
dow application.elf
run
--hs
Thnq.,.
how to check XMD Console and any  XMD settings is there?
