Visitor docfellows
SDK Unable to detect JTAG cable when programming flash
I am attempting to program the flash on a Zynq XC7Z030 in SDK on a standalone (non-networked) machine and it is is giving me an error that it cannot detect the JTAG cable.
The output from the console is as follows:
Connecting to hw_server @ TCP:127.0.0.1:3121
Connected to hw_server @ TCP:127.0.0.1:3121
Available targets and devices:
Target 0: jsn1
Target 1: jsn2
Target 2: jsn-DLC10-0000180feced01
ERROR: Unable to detect JTAG cable
I am able to program the bitstream directly to the FPGA -  this error seems to be unique to programming flash. I am using a Xilinx Platform Cable USB II. Any ideas why this would be happening?
Re: SDK Unable to detect JTAG cable when programming flash
Hello @docfellows
Which flash you are using on your board?
Please provide complete log generated by tool.
Bhushan
Visitor docfellows
The flash type being used is qspi_single (the board is a PicoZed 7030 housed on an AVNET PicoZed FMC Carrier Card Gen2).
The entire console output is:
cmd /C program_flash -f C:\Users\mfellow\workspace\Hello_Zed\bootimage\BOOT.mcs -offset 0 \ -flash_type qspi_single -fsbl C:\Users\mfellow\workspace\ZED_FSBL\Debug\ZED_FSBL.elf \ -cable type xilinx_tcf url TCP:127.0.0.1:3121
****** Xilinx Program Flash
****** Program Flash v2017.4 (64-bit)
  **** SW Build 2086221 on Fri Dec 15 20:55:39 MST 2017
    ** Copyright 1986-2017 Xilinx, Inc. All Rights Reserved.
Target 0: jsn1
Target 1: jsn2
Observer sheheeraismail
Working on SDK 2017.4 and going back on Lab tutorials Lab 07 to program QSPI flash, I have the same problem.
Also, the 'Program Flash' tool asks for FSBL elf file to be specified. can you please guide here.
I resolved this by following these steps
1. In xsct window, i connect to the hardwrae server
connect -url tcp:127.0.0.1:3121
connect -list //to check that tcfchan is there
2. Go to Xilinx -> program Flash -> Device , remove 'Auto-detect' and instead click on 'Select', uncheck the Auto-Detect box. The Zynq board on JTAG should have already been connected here and I assume you have previously been able to program FPGA as well. See the attached image.
The culprit in my case is the Auto-Detect, remove it and put the board ID here.
