dp0013
SDK error -- invalid hardware project
For some reason I cannot run my program on the Microzed board even though it ran perfectly fine just 3 days ago.  When I hit "Run As" --> "Launch on Hardware (GDB)", I get the error in the picture provided (Error while launching program: Invalid hardware project in launch configuration....").   I get a similar error if trying to launch in Debug mode (some Linux Agent connection timeout error, even though I'm using Windows 10).
My bsp and application are all showing zero errors or warnings.  My design obviously is not the issue either as it successfully generated a bitstream in Vivado before being sent to SDK.   What is going on and how do I solve this??
dp0013
I'm using Vivado 2018.2.
