Visitor valekiri
SEM Core support for Zynq Ultrascale + family.
I was wondering when and if Zynq Ultrascale + family will support use of the SEM core. It seems Kintex Ultrascale + and Virtex Ultrascale + are supported and Zynq are not.
Visitor valekiri
Re: SEM Core support for Zynq Ultrascale + family.
Thank you Krishna. I suppose I need to wait a bit for that.
Val
yes it supported . check list of supported devices
http://www.xilinx.com/products/intellectual-property/sem.html
Thanks and Regards
Balkrishan
Visitor valekiri
Hello Balkrishnan,
I have just noticed that in the manual 3.1 it says "In 2016.1, only KU9P is supported in pre-production capacity and has been verified in hardware."
I downloaded and tried out with 2016.2, however I got the same result, where if KU9P is selected it is shown in the list. However, any other Ultrascale + device causes the SEM core to dissapear from the list.
Any workaround is appreciated.
Val
Hi Val,
SEM IP support for zynq ultrascale+ MPSOC is in the roadmap and you will see in the coming versions made available
--Krishna
Visitor valekiri
Val
