SP605: BPI FLASH Read Problem
I have a problem reading from the BPI FLASH on the SP605. The problem is that the 'flash_wait' signal is never asserted indicating that the data is valid after a synchronous read, see attached. I can write to the FLASH (verified via readback using IMPACT) so clocking, reset and pinout is correct.
Any ideas?
Simon
I found the problem....page 19 of the SP605 schematic clearly states 'Synchronous mode not supported'. This is probably because the FLASH_CLK is not connected to the FPGA and therefore not driven.
Verify SW1 settings:
SW1.2 = OFF
SW1.1 = OFF
If any board problem exists the following AR http://www.xilinx.com/support/answers/40399.htm helps.
I can verify that SW1.1 & SW1.2 are both OFF.
It is worth pointing out that I am not trying to program the FPGA from FLASH at this stage just writing/reading data to/from it.
I don't think that there is anything wrong with the FLASH as I can read it's contents via IMPACT. The problem must be the way that I am interfacing with the FLASH, specific to a read as writing is working correctly.
Is there a signal that is only used during a read that I am not driving correctly?
