Observer bobbyl
SPI pins
Where can I find which pins to put in the constraints file to use the SPI interface post-configuration? I'm using an XC7A50T-2CSG325 on a PicoEVB board.
Re: SPI pins
@bobbyl
The schematics that came with your board should identify the FPGA pins that you need.
For example, the schematic found <here> might be for your board.  I assume you are referring to the SPI interface that connects the FPGA to the Flash memory, U2?
For this interface, the schematic shows that the FPGA pins (K16, L17, J15, J16, L15, and FPGA_CCLK_O_B) are used.  In your HDL, you can access all these pins directly except FPGA_CCLK_O_B, which must be accessed via the STARTUPE2 primitive (port USRCCLKO) described on about page 595 of UG953.
Cheers,
Mark
Re: SPI pins
@bobbyl
Cheers,
Mark
回复: SPI pins
Here is an AR on this:
https://www.xilinx.com/support/answers/63174.html
Simon
Observer bobbyl
回复: SPI pins
Thanks folks
