SVF to pattern generator signals
   I am looking to take an SVF file that I generated to program the FLASH firmware using an MCS/BIN file and I would like to create a pattern generator pattern that I can use to update the flash using the pattern generator in the field.
   My question is if anybody has ever successfully done this?    The SVF file is fairly extensive and I am not sure where delays might be needed etc.
   Another question is if anybody knows of any training options for learning how to convert an SVF file into usable signals that I can program into a pattern generator.
   Below is a copy of the comments portion of the SVF file so you can see what all the file is doing, and also I have put an image showing how the SVF file was setup.
2019-09-16 08_25_03-HS89_6x6 - [E__F_HS89_HS89_6x6_FlashProgramming_BRANCH_HS89_6x6.xpr] - Vivado 20.png
// config/idcode
// config/jprog
// Modify the below delay for config_init operation (0.100000 sec typical, 0.100000 sec maximum)
// config/jprog/poll
// config/slr
// config/start
// config/status
// config/idcode
// detect/spi/setclk
// spi/init1
// detect/spi/readid
// spi/init1
// spi/reset
// spi/init1
// spi/select
// spi/write/enable
// spi/erase/run/sector
// Modify the below delay for sector erase operation (0.250000 sec typical, 1.000000 sec maximum)
// spi/write/enable
// spi/write/enable
// spi/program/run
// Modify the below delay for program operation (0.000330 sec typical, 0.001200 sec maximum)
// spi/write/enable
// spi/program/run
// spi/write/enable
// spi/program/run
// Vivado Device xc7s50_0 mx25l6433f-spi-x1_x2_x4
// Vivado CfgMemOperation 0 EraseCheck ProgramCheck IOTerm=pull-none
Tim
回复: SVF to pattern generator signals
Check this: https://www.xilinx.com/support/documentation/application_notes/xapp058.pdf
Is it what you are looking for?
I don't get the question, what kind of pattern generator you are planning to design?
If you were asking how to reduce the time that playing a SVF takes, the only thing you can 'reduce' is the Run-Test-IDLE time. Usually SVF gives extra long time to this step. You can reduce the RTI time by multiplying all of the them by a fraction: you need to test to find out for a specific device, how small this fraction can be.
@iguo ,
   Sorry my question was a little confusing.
   The pattern generator I will be using is an ATE Digital Instrument where I generate pattern files to control the digital I/O pins.   I am looking to use the ATE to communicate on the JTAG bus in order to update firmware in the field.   So I am looking for any advice from anybody who may have done something like this.
Tim
@iguo ,
   Thanks for this link.   It appears this should get me what I need.   As long as I can generate an XSVF instead of SVF this document should help me convert that into usable patterns.
Tim
It's not necessarily to generate XSVF. The code can play SVF as well. Just that XSVF has a even smaller size then SVF.
