rmogster
Script to generate mcs
I have a tcl script that I run to compile my project.  Everything works great until I get to the very end.
The tcl command to generate the mcs file fails because it can't find the bit files.  Sine this is a tcl script, I heave used several "set" commands to define the file paths.  The tcl command I use to generate the mcs file does not work with the "set" paths.
The following command fails, tool claims it can't find the file reaper_gold.bit.
write_cfgmem -force -format mcs -size 32 -interface SPIx1 -loadbit {up 0x00000000 "$bit/reaper_gold.bit" up 0x01000000 "$bit/reaper_silver.bit" } -file "$bit/reaper.mcs"
The following command works, where I expanded the definition for $bit.
 write_cfgmem -force -format mcs -size 32 -interface SPIx1 -loadbit {up 0x00000000  "C:/Xilinx_projects/Spaceflight/reaper/lay/reaper.runs/impl_1/reaper_gold.bit" up 0x01000000  "C:/Xilinx_projects/Spaceflight/reaper/lay/reaper.runs/impl_1/reaper_silver.bit" } -file "$bit/reaper.mcs"
The tcl script has to be protable over several different machines, so the path cannot be hard coded.
How do I make this work?
Thank you,
Rolf
gurupra
Hi @rmogster
The parameters for write_cfgmem seems to expect absolute paths  hence you are running into issues.
Alternatively why don't you use something like this:
set bit_path "C:/Xilinx_projects/Spaceflight/reaper/lay/reaper.runs/impl_1
cd $bit_path
write_cfgmem -force -format mcs -size 32 -interface SPIx1 -loadbit {up 0x00000000 "./reaper_gold.bit" up 0x01000000 "./reaper_silver.bit" } -file "./reaper.mcs"
gurupra
Hi @rmogster
cd $bit_path
rmogster
that works.
