Observer dmi_iii
Spartan 3E 1600 bitstream (bit) + Microblaze program (elf) on SPI Flash loading
Dear Xilinx,
I would like to make MCS file from bitstream (.bit) and program (.elf) file for my M25P16 SPI Flash on Spartan 3E-1600 Microblaze Development Kit to have the automatic loading the firmware after switching on.
I checked the my design via SDK (by Xilinx Tools->Program FPGA) and Run->Run. My application for Microblaze works properly.
I added two these files to Impact utility (by using Create PROM File-> SPI Flash->Configure Single FPGA and by chosing 16M and setting to Add Non-Configuration Data Files (YES). Afterwards I generated MCS and wrote it to Flash. After switching off/on I noticed that my bitstream was downloaded (my led started to blink) but the program didn't started.
What I did wrong?
Should I change the linker's parameters?
Thank you!
With Best Wishes,
Dmitrii
