alekos2313
Spartan 6 copy protection options
Hello all,
I am new to FPGA, and I have worked with Spartan-6 for my project.
I am now trying to figure out what are my options for protecting my design. I went through doc UG380,
and I am a little confused with my options. For configuration the final board will use a simple external SPI flash, not sure if it will be Slave or Master mode. What I need to know is what are the options for protecting the bitstream from copy in small Spartan 6 devices XC6SLX9. I am under the impression that only the large devices in the family support encryption, but maybe this is wrong. Also, from what I know from microcontrollers, the most common way is to programm fusebits, that lock jtag and any form of read/verify commands, and only allow erase and overwrite. But this would not be enough in this FPGA, since the bitstream can be duplicated from the external flash. So I guess I need to use some Spartan6 feature or IP core ? I am pretty confused,
please give me a simple presentation of my options here.
Thank you
Alex
ddn
Hi @alekos2313,
Yes your device does not have encryption option.
Device DNA  means a unique ID for each FPGA will be generated and is permanently programmed into the FPGA.
Function of Device DNA : Prevent the design from operating (or operate in a limited manner) if unique identifier is not recognized.
For example : If someone steal your bistream and tries to configure his FPGA, then it will not happen, because unique identifier is not recognized.
Note : in general device DNA will be present for every device, but still bitstream can be read back.
For your case, please set security option to "level 1" and persist to "no".
Note : for flash we dont have any control. anybody can readback from flash.
Try referring this XAPP780, which may help you.
Deepak D N
Please Reply or give kudo or Mark it as an Accepted Solution.
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
ddn
Hi @alekos2313,
I found this below information from page 21 of UG380 (v2.10).
To protect the bitstream from FPGA has well as from Flash, AES is the best and effective way to protect the bitstream. Since if anybody reads back from flash also bitstream will be encrypted and it will be of no use.
Other options are, if you doing readback through JTAG, keep the Security option to LEVEL1 in bitstream setting.
                              if you doing readback through selectMAP, keep persist option to No.
Deepak D N
Please reply or give kudo or mark it as an Accepted Solution.
Deepak D N
alekos2313
Hello, thank you for a fast and good answer.
So to verify that I got  it, in smaller devices like mine(XC6SLX9) encryption is not supported, but the unique device id  is used to create unique bitstreams that are only working on the device that they were designed for. Is that correct?
If so, then where can I look for application note + examples? I imagine that there are tools
that can help in upgrades too. For example, If I programm 10 devices, each with same bitstream (except for the authentication part) then how would I update them with a new firmware in the future?  will I need to bring all 10 devices in my lab and create a new bitstream for each? or is the authentication part somehow separated and maintained for future use and upgrades?
Thank you,
Alex
ddn
Hi @alekos2313,
Deepak D N
Deepak D N
