Spartan6/Dual-Purpose Configuration Pins/SPI-Flash/User I/O /Pull-Down
I have build a PCB where I am able to program from Impact Software successfully, using FLASH-SPI Master configuration using a BGA 196 Spartan 6 Package. From ug380 pdf, page 76 it claims that they are Dual-Purpose pins which I used as I/O pins for a design. In addition, from ug385 pdf, page 38 the pins that I have used are label as "IO_L64N_D9_2" (P3) and "IO_L49N_D4_2" (P5).  Those two pins are used for Pull-Up network push buttons, however they don't work properly. They are constantly pull-down, although I am using those two pins (P3,P5) as input logic in my VHDL code.
My question is, can I program those two pins (P3,P5) to be in FLOAT state after the configuration is done?
I would like to use these two pins ONLY as user input purpose.
Thank you,
inoth79
This reply concerns all the newbies just like me, as it turns out you can use this type of pins I have mentioned above and for my PCB design a pin from VCCO_2 bank was shorted to GND from incorrectly soldering a mosfet IC. Once I fixed that short, all the pins from VCCO_2 worked fine. I hope this post can help someone because I haven't received any suggestions related to this problem. Thus, Dual-Purpose Configuration pins can be used after booting Spartan 6, although they are some posts in this community claiming that you can not.
