08-28-2013 06:36 PM
I'm finalizing a schematic before sent for layout. I was hoping to get a sanity check on the connections.
I'm using the LX9 in the TQ144 package and have:
Pin 65 (IO_L3P_D0_DIN_MISO_MISO1_2) connected to the flash's MISO.
Pin 64 (IO_L3N_MOSI_CSI_B_MISO0_2) connected to the flash's MOSI
Pin 38 (IO_L65N_CSO_B_2) conected to the slave select line
Pin 70 (IO_L1P_CCLK_2) connected to sclk
Sorry for the simple question, but given the myriad pins with their multiple functions I just want to make sure I get this right. Thanks!
D
08-30-2013 08:56 AM
series termination resistors are ideally placed near the signal source (driver).
parallel termination resistors are ideally placed at the very end of the signal trace furthest from the signal source.
do not use series termination for multi-load signals, only for signals with single source and single load.
There are more layout guidelines, depending on your schematic design, but these are the most useful ones for the configuration connections.
-- Bob Elkind
08-28-2013 09:13 PM
The connections you list are superficially correct, but too incomplete to guarantee success. The guide for you should be UG380 Figure 2-12. Are there any differences between Figure 2-12 and your board design? If so, suggest you list each of these differences and post them to this thread for review.
-- Bob Elkind
08-29-2013 12:22 PM
Thanks for your reply, Bob. Everything else looks like the Figure 2-12. I just wanted to sanity check the MISO/MOSI pins given the myriad number of pins that contain the words "MISO" and "MOSI" in their names. Much appreciated.
D
08-29-2013 01:23 PM
Do you know what directions to give to the layout designer for placement of termination resistors?
-- Bob Elkind
08-29-2013 11:27 PM
The guide provies some reasonable guidelines. I figured I could send that along with the layout guide (UG393). Looks like the main constraint is the parallel termination and no stubs. Is there any other info you'd recommend passing along/looking for? Thanks so much for your help!
08-30-2013 08:56 AM
-- Bob Elkind
08-30-2013 11:45 AM
Thanks so much for your help, Bob. Much appreciated.
