krn-krn
Split the flash
i am able to successfully program the flash and boot (spartan-7)fpga from it,But how to split the flash in two half sectors and then test read-write operations,i am using S25FL128SAGNFI000 spi Flash,and i am using vivado 2017.4
There is no procedure for "splitting" the flash.  Instead, you simply use address locations 07FFFFFh to 0FFFFFFh for your own read/write.  By using these high address locations, you will avoid overwriting the bitstream.
@krn-krn
  1. The S25FL128S flash holds 128 mega-bits or 16 mega-bytes of data.  The flash memory is organized in bytes and the bytes have addresses from 0000000h to 0FFFFFFh.
  2. Table 1-1 in UG470 shows that Spartan-7 bitstreams have sizes from 8-32 mega-bits or 1-4 mega-bytes.  So, the largest Spartan-7 will use only about ¼ of the S25FL128S flash memory.
  3. Bitstreams are normally stored in flash starting at address, 0000000h.  So, the largest Spartan-7 will use locations 0000000h to 03FFFFFh.
  4. So, you can split the flash in half and use locations 07FFFFFh to 0FFFFFFh for your own read/write – and you won’t overwrite the bitstream.
  5. You can read/write the flash from your HDL using the existing SPIx1 interface between the FPGA and the flash, which consists of the four FPGA pins called MOSI, DIN, FCS_B, and CCLK.  After FPGA configuration, all of these pins become user IO, except CCLK, which you can access using the STARTUPE2 primitive (ref UG953(v2020.1), page 583).
  6. Xilinx provides IP to read/write flash using SPI (see AXI Quad SPI in document PG153).
  7. You can also write your own HDL for SPI communications with flash.  See <this> post for some guidance.
Cheers,
Mark
krn-krn
I am new to fpga,its my first project,where should i edit the address ,
if you have screenshots share me ,flash size is 128 megha-bytes,If you have any examples related to that please share me.
krn-krn
Can we edit the address in "Write Memory Confiration File" widow?
In addition to the bitstream, what do you want to write to the flash?
krn-krn
Just i want to check read and write operation,i followed this "So, you can split the flash in half and use locations 07FFFFFh to 0FFFFFFh for your own read/write" and i am able to see address are changing.
krn-krn
Thank you.
